jimbobtom Posted August 4, 2020 Posted August 4, 2020 Hi, New to the forum. I have an Audi A4 Cabriolet 2004 3.0l petrol. i am forever getting water sounds in the passenger footwell and the scuttle pan is regularly full. i think this is playing with my electrics a bit also. I initially thought it was the rear window on the soft top which had perished in places but upon fixing this it still happens (after trying to fix it several times i came across Tiger seal sealant which is awesome and highly recommended). The water is getting in somewhere or there are some drainage holes somewhere i have missed. Has anyone had this problem and can help me out? I love the car but if i don't get it fixed this time, it will have to go 馃槥 regards, Jim
audia4b5kev Posted August 4, 2020 Posted August 4, 2020 the battery place fills up with water if drain plugs blocked take battery off and poke hole in grommet job sorted
Steve Q Posted August 4, 2020 Posted August 4, 2020 I agree with Kev, definitely look at the battery area. It's it playing up with the electrics then it may have affected the CCM module. Also worth looking at the pollen filter housing as this cracked on my a6. Cheers Steve
jimbobtom Posted August 4, 2020 Author Posted August 4, 2020 On 8/4/2020 at 3:56 PM, audia4b5kev said: the battery place fills up with water if drain plugs blocked take battery off and poke hole in grommet job sorted Expand appreciate this Kev thank you i will investigate tomorrow. I also get an issue with my central brake light. i replaced it and it worked for a while but it went out again. I think water is getting in the back also. Is there any drainage holes in the back?
jimbobtom Posted August 4, 2020 Author Posted August 4, 2020 On 8/4/2020 at 5:05 PM, Steve Q said: I agree with Kev, definitely look at the battery area. It's it playing up with the electrics then it may have affected the CCM module. Also worth looking at the pollen filter housing as this cracked on my a6. Cheers Steve Expand Thanks Steve, i will look at this also.
audia4b5kev Posted August 4, 2020 Posted August 4, 2020 YIP THAT TO STEVE CHECK CONECTIONS TO AM SURE THERE STUFF UNDER PASSNGER SIDE CARPET THAT PLAYS UP TO WITH WATER
Steve Q Posted August 5, 2020 Posted August 5, 2020 On 8/4/2020 at 7:37 PM, jimbobtom said: Thanks Steve, i will look at this also. Expand You're welcome. Good luck
