TheTJW Posted August 15, 2020 Posted August 15, 2020 Hi, is it possible to add option packs after you've bought an Audi A1 - so for instance could I get the Tech pack added after I've bought an A1 without it?
Magnet Posted August 16, 2020 Posted August 16, 2020 Hello Tim, I think you will find that although it would be technically possible to add the ‘options’ after the car has been built, it generally proves to be even more costly that opting for it prior to the build. Kind regards, Gareth.
Steve Q Posted August 16, 2020 Posted August 16, 2020 I agree with Gareth on this. Obviously retrofitting companies will be cheaper than Audi. But the parts and labour costs often make upgrades prohibitive. Worth seeing if Audi will do it. But not all dealers will. Cheers Steve
TheTJW Posted August 16, 2020 Author Posted August 16, 2020 Ok, thanks for this. It's what I suspected, as the options are expensive enough anyway. Also, do you know if the flappy paddle gear shifters on the S Tronic usually come as standard, or is this another option that you have to find a used car has?
Steve Q Posted August 23, 2020 Posted August 23, 2020 Very good question, I'm not entirely sure on that one.
