Par789 Posted August 19, 2020 Posted August 19, 2020 Hi guys really need your help car drove fine then a couple of jerks then loss of power to nearly nothing, starts fine idles fine but won't rev over 1100rpm until a bit warm then drives like it's a 1.0litre . Foot flat to floor won't rev over 1100 but let off pedal and it will climb have changed maf sensor and foot pedal assembly, doesn't show any fault codes any help greatly appreciated
Steve Q Posted August 22, 2020 Posted August 22, 2020 Sounds like it's in limp mode. Or the turbo could be on the way out?
Sam Harding Posted September 13, 2020 Posted September 13, 2020 On 8/19/2020 at 9:44 PM, Par789 said: Hi guys really need your help car drove fine then a couple of jerks then loss of power to nearly nothing, starts fine idles fine but won't rev over 1100rpm until a bit warm then drives like it's a 1.0litre . Foot flat to floor won't rev over 1100 but let off pedal and it will climb have changed maf sensor and foot pedal assembly, doesn't show any fault codes any help greatly appreciated Hello mate what engine do you have? I have a 2.0 TDI and had similar problem. I cleaned MAF sensor didn’t work, changed fuel filter didn’t work, changed EGR valve didn’t work. It turned out to be a turbo boost pipe with a small split in it, did the job!!! Runs like a dream now. Sam
