Phil slinkey Posted August 28, 2020 Posted August 28, 2020 Hi all, I’ve got n A6 avant 2012 and there is water in the driver side foot well I’ve checked the door seals and Everything seems ok, however, the carpet is damp behind the foot pedals, has anyone got any suggestions, thanks
Steve Q Posted August 28, 2020 Posted August 28, 2020 Very common on holder vag cars. Check the Skittles panel in the engine bay. Drain holds could be blocked with muck abd leaves. If battery situated there, check the battery tray as the drain holes are probably blocked.
A6 C7 ULTRA BLACK EDITION Posted September 29, 2024 Posted September 29, 2024 On 8/28/2020 at 1:50 PM, Phil slinkey said: Hi all, I’ve got n A6 avant 2012 and there is water in the driver side foot well I’ve checked the door seals and Everything seems ok, however, the carpet is damp behind the foot pedals, has anyone got any suggestions, thanks Hi I'm also having the seme problem and I've done some investigation into it over quite a few websites and a few mechanics apparently it the door speaker mount seal . There is a mount that bolts to the inside of the door that has a seal that fails . The speaker then bolts to the mount which I also think has a seal to. When I rains heavy water runs down the window into the door panel by design but when the speaker seal fails the speaker is right at the bottom and the seals consetualy getting wet then drying out causing it to crack . My car been back in under warranty 3 weeks ago and I told them then what the fix was but they fitted the full internal door seal instead hence I still have the problem. I hope this I helpful to you. I had someone pouring water onto the door window as I took a video clip at the bottom of the door under the speaker between the door card and the door. If you have a way I could send the clip to you or try do what I did. 1
