Danhems82 Posted August 30, 2020 Share Posted August 30, 2020 Hi all I have a 2011 black edition a4 2.0tdi. I've had it for three years now and have been unable to find a device that allows Bluetooth streaming. Does anyone have any recomendations please? It has the b and o set up with the plug in the globe box Cheers! Quote Link to comment Share on other sites More sharing options...
CupraDine Posted September 1, 2020 Share Posted September 1, 2020 If you have the AMI port in the glove box, try the Bovee Tune2Air AMI or similar. This is expensive but worth the money according to others. I use a cheaper one which does have the odd hiccup and doesn't support the media controls. Search for "bluetooth a2dp ami" or similar to see other alternatives. AMI is the port in the glove box, A2DP is the bluetooth streamning standard. Also your device (phone or whatever you use) will need to support at least 2 bluetooth connections simultaniously (most modern smartphones do). Quote Link to comment Share on other sites More sharing options...
karandle Posted September 8, 2020 Share Posted September 8, 2020 On 9/1/2020 at 10:40 PM, CupraDine said: If you have the AMI port in the glove box, try the Bovee Tune2Air AMI or similar. This is expensive but worth the money according to others. I use a cheaper one which does have the odd hiccup and doesn't support the media controls. 8 ball pool Search for "bluetooth a2dp ami" or similar to see other alternatives. AMI is the port in the glove box, A2DP is the bluetooth streamning standard. Also your device (phone or whatever you use) will need to support at least 2 bluetooth connections simultaniously (most modern smartphones do). Thank you I will give it a look Quote Link to comment Share on other sites More sharing options...
