piercemorgan Posted September 7, 2020 Posted September 7, 2020 Recently I noticed my passenger side wing mirror and window stopped working, shortly after my passenger door would not unlock. I believe some cables have come loose in the door hinge however with the door locked I cannot diagnose this. My main focus is to open the door however I have not found anyway to unlock it using the fob / door lock. So far I have been able to pry open the top part of the door card and then I have been able to remove the panel which leads to the locking mechanism. Pulling the wire leading to the inside handle and the rod coming from the outside handle have done nothing. I was wondering if there was any way to unlock the door from the inside. Once the door is open I would be able to fix the wiring and lock mechanism however I'm struggling to find a way to open the door.
cliffcoggin Posted September 7, 2020 Posted September 7, 2020 Pierce. Cable damage seems to be a common fault, See other recent threads here.
