  • 2 years later...
You鈥檒l need to soak it with WD40 and leave it for 15mins or so. Then go steady with a 17mm Spanner 馃敡 on the top half of the connecting nut 馃敥 slowly applying pressure anti-clockwise 馃攧. It will come off without bending the pipe but the pipe is very solid and difficult to bend really.
Just be extra careful on the other end not to rush and go in to heavy handed as it鈥檚 commonly done to snap off the Oil pressure Sensor which sits just under 2 inches away to the right..
