Izzer Posted October 4, 2020 Posted October 4, 2020 Hi, when I close the Boot on my Q3, once its shut it makes this clicking noise for a few seconds just after its locked in. Does anyone know what this could be please?
BensonWedges Posted June 5, 2021 Posted June 5, 2021 Did you figure this out please? Mine has started doing it recently. Boot closes and pulls in close as normal and then I get a sound like a servo triggering repeatedly, or a gear skipping, maybe?
BensonWedges Posted June 5, 2021 Posted June 5, 2021 Just found the solution in case anyone else is looking. I simply pressed down on the boot lid from the outside as it closed. It didn’t make the noise. Opened and closed it as normal a few times after and it’s fine now. Must’ve been something blocking it - dirt, rubbers lifted a little, not sure. But the noise has stopped.
Steve Q Posted June 5, 2021 Posted June 5, 2021 8 hours ago, BensonWedges said: Just found the solution in case anyone else is looking. I simply pressed down on the boot lid from the outside as it closed. It didn’t make the noise. Opened and closed it as normal a few times after and it’s fine now. Must’ve been something blocking it - dirt, rubbers lifted a little, not sure. But the noise has stopped. Glad you got sorted ☺️
Steve Fletcher Posted April 1, 2022 Posted April 1, 2022 Did you resolves this? My Q3 has started doing the same (it has the electric tailgate - which on setting continues to 'run' for a few seconds)...
Massoud Posted February 12 Posted February 12 (edited) I fitted a new unit from Audi,and then decided to check the faulty one,I opened up the unit(strike plate with motor)and found the main gear's teeth was damaged. New unit from Audi cost me £260 Edited February 12 by Massoud Addadding photoing pho 1
Massoud Posted February 12 Posted February 12 (edited) I added photo to my file. Edited February 12 by Massoud
