den9112 Posted October 18, 2020 Posted October 18, 2020 Hi I have a A3 cab 2011 all windows work but I have a noisy drivers window, I have taken the door card off and operated the window and tried to figure out if its motor or regulator gears. To me it sounds as though the motor is the culprit, if it is I can change it easy enough but before I do is there any coding numbers I need to keep change etc, I do have vcds any help would be appreciated thanks. VID not great but it may give an indication VID_20201018_105119.mp4
den9112 Posted October 18, 2020 Author Posted October 18, 2020 Hopefully a better video VID_20201018_145133.mp4
