boreks Posted October 19, 2020 Posted October 19, 2020 hi , i have a6 c6 diesel 140 hp . switch on 10-15 secondes run and by self switch off . and after switch on again and again 10-15 secundes work and cuts off . i have half a tank fuel, new air, fuel filters. battery as well ok i try on other cars( mercedes e320 and audi a4) working nice .any sugestion ??? here is log : Tuesday,06,October,2020,13:03:06:03954 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 20.4.2.0 HEX-V2 CB: 0.4513.4 Data version: 20200730 DS317.0 www.Ross-Tech.com VIN: WAUZZZ4FX8N049346 License Plate: xxxxxx Mileage: 342940km-213093mi Repair Order: Chassis Type: 4F (4L0) Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 4F 52 53 56 61 62 72 VIN: WAUZZZ4FX8N049346 Mileage: 342940km-213093miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No SW: 03G 906 016 MF HW: 03G 906 016 MF Component: R4 2,0L EDC G000CG 1142 Revision: --H05--- Serial number: Coding: 0000076 Shop #: WSC 66565 257 00032 VCID: 73B3DB9447B5DFB35F1-8026 1 Fault Found: 006215 - Please check DTC Memory of ABS Controller P1847 - 000 - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 31 Reset counter: 255 Mileage: 342942 km Time Indication: 0 Date: 2007.05.22 Time: 13:11:35 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 11.78 V Bin. Bits: 00101000 Torque: 0.0 Nm Bin. Bits: 00000100 Readiness: 0 0 0 1 X ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4F0-910-517.clb Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T Component: ESP8 front H01 0070 Revision: 00000000 Serial number: 00000000000000 Coding: 0020856 Shop #: WSC 02325 758 00200 VCID: 6597B5CCF9613103C15-8030 2 Faults Found: 00778 - Steering Angle Sensor (G85) 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 2 Fault Frequency: 19 Reset counter: 42 Mileage: 342942 km Time Indication: 0 Date: 2007.05.22 Time: 14:12:12 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0282 Hex Value: 0x001E Hex Value: 0x3E90 Hex Value: 0x00FF 01486 - System Function Test Activated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 18 Reset counter: 42 Mileage: 342942 km Time Indication: 0 Date: 2007.05.22 Time: 14:12:55 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x0282 Hex Value: 0x0021 Hex Value: 0x4190 Hex Value: 0x00FF End----------(Elapsed Time: 01:36, VBatt start/end: 12.3V/12.3V)-----------
