Hello,
Will mats designed for the pre-facelift A4 Avant (pre 69) fit the current A4 Avant? Because I can’t see any for ‘2019 onwards’; In the item description on various websites, at best it’s listed as ‘2016-2020’ or ‘2016-2019’.
I can’t find this information anywhere on line!
Also, I see that each generation has a code associated with it; ‘B9’ for example. I don’t know what this means or what it is, but what would it be for a 2020 A4 Avant? I saw ‘8W’ somewhere?
Thank you,
A.
  • 3 weeks later...
B9 is the current model code. The code is assigned to the chassis. Any b9 mats should fit as long as you get the correct one for your gearbox. Ie manual mats might not fit automatics footwells and visa versa
