jimmychow Posted October 22, 2020 Posted October 22, 2020 1. More Easily Changing Wheels Changing wheels on your own is never easy work for European cars (BMW, Audi, VW, Porsche…). When removing and installing wheels that utilize the factory wheel bolts the process can be frustrating, holding the wheel up with your legs, lining up the holes, and threading the bolts all at the same time. What’s worse, on a rainy day, at the high-speed roadside or other harsh environments, it is hard to align the holes, can easily get mad when trying again and again, but fail again and again. Compared with the Japanese cars (Honda, Toyota…), the studs are mounted in the hub and stuck out beyond the brake rotor hat. The wheels are mounted using lug nuts, which are screwed onto the studs. This makes it easier to disassemble and assemble wheels without having to worry about lining everything up. By using the wheel studs conversion, you can make the European cars (BMW, Audi, VW, Porsche…) “transform” into the form of the Japanese cars (Honda, Toyota…), so it is called “conversion”. 2. For Wheel Spacers Needs For some situations, such as widening the wheelbase, or changing to a larger brake caliper, if the rotor hat cannot pass the brake caliper, the wheels won’t be fastened tightly, which cause an accident. In such a case, wheel spacers must be added. By correcting the offset, truly guarantee safety. After installing wheel spacers, the factory wheel bolts will not be long enough, reducing the number of laps for threading. In the case of intense driving, it will cause kinds of security issues. Meanwhile, the length of the stud conversion can be customized flexibly, which makes it possible to install different offset aftermarket wheels. 3. The Aggressive Appearance By installing a stud conversion kit, you can use wheel lug nuts. On the market, there is numerous lug nuts style, some of them are really pretty and cool. How to install them on your BMW, Audi, VW, or Porsche? The studs conversion will do the job perfectly. Besides, the nuts can be replaced more flexibly, such as wheel lock nuts, lightweight and high-strength nuts. These lug nuts make your car look more manly and aggressive. Video: https://www.youtube.com/watch?v=fi-y5_IpGmo&feature=emb_title Passage:👇 https://www.bonoss.com/why-use-stud-conversion-kit-instead-of-wheel-bolts-cai.html
