LokiKdiney Posted October 24, 2020 Posted October 24, 2020 Hello everyone. I have a 2017 8V S3, with a 2.0 TFSI engine. I've ordered some aftermarket wheels, which I know the factory lugs aren't going to fit. Diameter of the head on the OEM bolts is too big. Knowing that I should purchase a set of longer bolts or convert to a wheel stud conversion kit. There are three advantages of stud conversion: 1.They offer an easy way to align the wheel when mounting; 2.They allow for the safe use of different thickness wheel spacers; 3.It is compatible with both ball and conical seat lug nuts, which is suitable for most factory or aftermarket wheels. (Quoted from: why-use-stud-conversion-kit-instead-of-wheel-bolts ) Compared to buying a new set of bolts, stud conversion seems to a better choice. It is easier for wheel mounting. I have already get annoyed of these bolts. Thinking the studs should solve the problem.
Magnet Posted October 24, 2020 Posted October 24, 2020 Hello, Could you inform the forum what grade of steel yours are made from? Kind regards, Gareth.
