Eno Posted December 15, 2020 Posted December 15, 2020 Hello all, first post on here. bought an sq7 not long ago, has about 70k miles on it. So one day the start stop stopped working. Take it for a check as i though might need a new batter but have the following error. ‘ P15B700 ‘ `electrically driven compressor Electrical Malfunction’ car drives fine with now and then some rough idle on cold starts. Anyone know of this or any advice
Mrvalooo Posted May 16, 2022 Posted May 16, 2022 Hi, i have this same problem… did you find out what it was?
Vitaliy Posted April 17, 2023 Posted April 17, 2023 Hi, did you find out anything, me as well have the same mistake. And the car drives as well fine!
Vitaliy Posted April 17, 2023 Posted April 17, 2023 On 12/15/2020 at 6:48 AM, Eno said: Hello all, first post on here. bought an sq7 not long ago, has about 70k miles on it. So one day the start stop stopped working. Take it for a check as i though might need a new batter but have the following error. ‘ P15B700 ‘ `electrically driven compressor Electrical Malfunction’ car drives fine with now and then some rough idle on cold starts. Anyone know of this or any advice Expand Good evening, please advise how you've solved the issue. I've got the same one, so appreciate some advise.
Magnet Posted April 17, 2023 Posted April 17, 2023 Hello Vitaliy, I might be worth sending the original poster a PM. Kind regards, Gareth.
Erkan Posted April 17, 2023 Posted April 17, 2023 On 4/17/2023 at 3:16 PM, Vitaliy said: Goedenavond, geef alstublieft aan hoe u het probleem heeft opgelost. Ik heb hetzelfde, dus graag wat advies. Expand
Vitaliy Posted April 18, 2023 Posted April 18, 2023 On 4/17/2023 at 10:14 PM, Erkan said: Expand Hi, I didn't understood the answer! Once more - I've got mistake as attached and same stuff as in initial message of this topic. So I'm asking if it was solved somehow, as I don't authorised dealer to check. And what is strange - car drives fine, I don't see any mistakes on dashboard! Or maybe it's some issue I shouldn't bother. Please share your experience.
Vitaliy Posted June 12, 2023 Posted June 12, 2023 Hi, to those who still has the same issue. This mistake says that electric turbine isn't working at all. The only way is to change it. But you need to change for following part number 057145601E. Because old models of this turbine will damage soon too. In this part number with E at the end they solved issue with high current which caused the damage. And after exchange you have better acceleration at the very beginning. And its really noticeable. 1
