den9112 Posted December 17, 2020 Posted December 17, 2020 Hi, i am in the process of fitting a new HU in my non bose 2011 a3 cabriolet (from Chorus) i have replaced the front speakers with some Focal components and all is running fine ..The A pillar on the cab is pretty easy to remove for the tweeters聽 but replacing takes a lot longer ,anyway i have now moved on to the rear were i am fitting some Herts 5.25inch and i have managed to run both pairs of speaker wires to the HU (no connection yet) ...now before i rush in a splice the wires to pick up the rear connections ,green and purple i am not sure were to join them as i notice the Connects2 block as the rear wires connected and that plugs in to the pioneer block then in to the HU ,do i pick up from pioneer in to HU or further down on the connects2 block..My car as only ever had two front speakers and never had a rear amp ..Any help before i go cutting away would be appreciated..Thanks聽
Sheffieldyorky Posted January 1, 2021 Posted January 1, 2021 Hi there Very quickly DO NOT let the "speaker stripe" and the "speaker non stripe" end touch even for a second, you will blow the board, NOT the fuse.馃拃 Far better to stick a bit of insulation tape on both ends till you are ready to fit insulated crimp terminals.
