SteveBarnes Posted December 19, 2020 Posted December 19, 2020 Hi all, just after some advice. I've been looking at a car (2006, 2.0l diesel) for a friend today which has had a diagnoses of ECU failure, however the car runs flawlessly despite it having engine management light, ABS and coolant temp lights on when I inspected it. I used a scanner to look for codes which cleared the lights, but gave the following.. Is there anywhere I should be looking or tests I can do to find where the fault lies? I am thinking there maybe a bad ground or cable break somewhere as opposed to ECU failure given everything is working as it should. Car Scanner ELM OBD2 DTC report Selected brand: Audi ============1============== P2100 Raw code: 2100 ECU: OBD-II Status: Confirmed OBDII: Throttle actuator control (TAC) motor - open circuit ============2============== P0117 Raw code: 0117 ECU: OBD-II Status: Confirmed OBDII: Engine coolant temperature (ECT) sensor - low input Audi: Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage ============3============== P2102 Raw code: 2102 ECU: OBD-II Status: Confirmed OBDII: Throttle actuator control (TAC) motor - circuit low ============4============== 0470 Raw code: 01D6 ECU: 19. CAN Gateway Status: Pending fault present, Pending fault present during this driving cycle, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request Audi: Common concern data bus Comfort in single-wire data transfer mode; Group data bus convenience in a single wire ============5============== 0290 Raw code: 0122 ECU: 03. ABS control unit Status: Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory Audi: Rear Left Wheel Speed Sensor-G46; Rear left speed sensor-G46; Throttle valve potentiometer-G69 signal too small ============6============== 1435 Raw code: 059B ECU: 03. ABS control unit Status: Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request Audi: Brake Pressure Sensor 1-G201; Brake pressure sender 1-G201 ============7============== 19557 Raw code: 4C65 ECU: 01. Engine control unit Status: Validated and stored in non volatile memory, Validated fault present at time of request Audi: P3101 Intake manifold flap actuator motor-V157: open circuit / short to ground; Intake manifold flap motor-V157 Open circuit / short circuit to earth ============8============== 17075 Raw code: 42B3 ECU: 01. Engine control unit Status: Validated and stored in non volatile memory, Validated fault present at time of request Audi: P0691 Radiator Fan Control 1: Short to Ground; Cooling fan control 1 short circuit to ground ============9============== 16501 Raw code: 4075 ECU: 01. Engine control unit[Archive (inactive)] Status: Validated and stored in non volatile memory Audi: P0117 Coolant Temperature Sensor-G62: Signal Too Low; Coolant temperature sender G62 signal too small ============10============== 19558 Raw code: 4C66 ECU: 01. Engine control unit Status: Validated and stored in non volatile memory, Validated fault present at time of request Audi: P3102 Intake manifold flap actuator motor-V157: no signal; Intake manifold flap motor-V157 no signal ============11============== 17056 Raw code: 42A0 ECU: 01. Engine control unit Status: Test has not been completed, Validated and stored in non volatile memory, Validated fault present at time of request Audi: P0672 Glow plug for cylinder 2-Q11: electrical failure; Glow plug cylinder 2-Q11 electrical fault in the circuit ============12============== 17057 Raw code: 42A1 ECU: 01. Engine control unit Status: Test has not been completed, Validated and stored in non volatile memory, Validated fault present at time of request Audi: P0673 Glow plug 3-Q12: malfunction in an electric chain; Glow plug cylinder 3-Q12 electrical fault in the circuit ============13============== 17058 Raw code: 42A2 ECU: 01. Engine control unit Status: Test has not been completed, Validated and stored in non volatile memory, Validated fault present at time of request Audi: P0674 4-Q13 glow plug, electrical failure; Glow plug cylinder 4-Q13 electrical fault in the circuit ============14============== 0483 Raw code: 01E3 ECU: 08. Heater and climate Status: Pending fault present, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request Audi: Auxiliary air heater control unit; Control unit for additional air heating ============15============== 16346 Raw code: 3FDA ECU: 17. Dashboard Status: Pending fault present during this driving cycle, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request Audi: Control block; Control unit ============16============== 0932 Raw code: 03A4 ECU: 42. Driver door electronic equipment Status: Pending fault present, Test conditions are met, Validated and stored in non volatile memory Audi: Driver Side Power Window Motor-V147; Motor window regulator driver's side-V147 ============17============== 0361 Raw code: 0169 ECU: 7D. Additional heater (VW TP2.0) Status: Pending fault present during this driving cycle, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request Audi: Heater, auxiliary heater-Z35; Heating element for additional heating-Z35; Bank1, fuel metering system 2 malfunction ============18============== P2102 Raw code: 2102 ECU: OBD-II Status: Pending OBDII: Throttle actuator control (TAC) motor - circuit low ============19============== P2100 Raw code: 2100 ECU: OBD-II Status: Pending OBDII: Throttle actuator control (TAC) motor - open circuit ============20============== 0470 Raw code: 01D6 ECU: 19. CAN Gateway Status: Pending fault present, Pending fault present during this driving cycle, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request Audi: Common concern data bus Comfort in single-wire data transfer mode; Group data bus convenience in a single wire ============21============== 1435 Raw code: 059B ECU: 03. ABS control unit Status: Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request Audi: Brake Pressure Sensor 1-G201; Brake pressure sender 1-G201 ============22============== 19558 Raw code: 4C66 ECU: 01. Engine control unit Audi: P3102 Intake manifold flap actuator motor-V157: no signal; Intake manifold flap motor-V157 no signal ============23============== 19557 Raw code: 4C65 ECU: 01. Engine control unit Status: Validated fault present at time of request Audi: P3101 Intake manifold flap actuator motor-V157: open circuit / short to ground; Intake manifold flap motor-V157 Open circuit / short circuit to earth ============24============== 17075 Raw code: 42B3 ECU: 01. Engine control unit Status: Validated and stored in non volatile memory, Validated fault present at time of request Audi: P0691 Radiator Fan Control 1: Short to Ground; Cooling fan control 1 short circuit to ground ============25============== 0483 Raw code: 01E3 ECU: 08. Heater and climate Status: Pending fault present, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request Audi: Auxiliary air heater control unit; Control unit for additional air heating ============26============== 16346 Raw code: 3FDA ECU: 17. Dashboard Status: Pending fault present during this driving cycle, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory, Validated fault present at time of request Audi: Control block; Control unit ============27============== 0932 Raw code: 03A4 ECU: 42. Driver door electronic equipment Status: Pending fault present, Test conditions are met, Validated and stored in non volatile memory Audi: Driver Side Power Window Motor-V147; Motor window regulator driver's side-V147
