Jessdale Posted January 15, 2021 Posted January 15, 2021 Hi there . How can I tell if a Allroad is 21/245/272 bhp ? Are there any visual clues ? Thanks
beemerboy9 Posted January 16, 2021 Posted January 16, 2021 I cannot tell you about the visual clues. However once you have homed in on your desired car, you will be able to tell from the V5. There are various websites that will confirm the engine size for a small fee. 204 BHP 159 gm CO2 245 BHP 165 gm CO2 218 BHP 145 gm CO2 272 BHP 149 gm CO2 From the outside you would know my car is an SE, but you would not be able to tell what engine it had. In my personal experience, no-one has ever knowingly falsely described the specification of their car. Hope this helps ...... I did read of one A5 where a clerk somewhere had failed to register the car correctly. It was sold Approved Used as a quattro but only had 2-WD. Once this error was detected the dealer took the car back.
56Doc Posted March 5, 2022 Posted March 5, 2022 Look for the build spec label, it’s in the spare wheel well in my 2015 Allroad, The codes you’re after start with ‘DD’ all below are for the V6 diesel variants. I have the 218ps (160KW ) engine, so the code is DD5 Others I’ve found are: DD1 - 221kw DD3 - 230Kw DD6 - 240 Kw DD7 - 190 Kw website is http://igorweb.org/equidec.aspx another useful site is: https://www.bezwypadkowy.net/media/kunena/attachments/63/audi-option-codes.pdf Hope this helps.
