Neil Sommerville Posted January 25, 2021 Posted January 25, 2021 Had an mot at audi next day dash board come on with sports differential malfunction Turned off the car and restarted, the fault didn’t return until the next time I restarted it
RS5GW Posted January 25, 2021 Posted January 25, 2021 Hi Neil... had a similar issue myself, one day all is OK, the next upon start-up I get ESC, TPMS, Adaptive Lights & Sports Diff warning lights. Checked on the forums, which suggest that maybe my battery was the culprit - which sounds plausible. Anyway, my RS5 is in with my local independent at the moment for some investigation & diagnostics, so far it's not the battery 😳
Neil Sommerville Posted January 25, 2021 Author Posted January 25, 2021 Thank you RS5GW ive looked on other forums and it could be differential sensor faults but hopefully not its booked in tomorrow with Audi This car has be faultless up till now !!! will update when I get the problem from Audi
Neil Sommerville Posted January 26, 2021 Author Posted January 26, 2021 Thank you RS5GW ive looked on other forums and it could be differential sensor faults but hopefully not its booked in tomorrow with Audi This car has be faultless up till now !!! will update when I get the problem from Audi
Neil Sommerville Posted January 26, 2021 Author Posted January 26, 2021 Hi too all My RS5 had an oil pressure sensor intermittent failure . Three sensors with the dual clutch differential and one sensor checks the other two for any discrepancies Just want it fixed , back too how it should be !!!!
