Had an mot at audi
next day dash board  come on with sports differential malfunction
Turned off the car and restarted, the fault didn’t return until the next time I restarted it
Hi Neil... had a similar issue myself, one day all is OK, the next upon start-up I get ESC, TPMS, Adaptive Lights & Sports Diff warning lights. Checked on the forums, which suggest that maybe my battery was the culprit - which sounds plausible. Anyway, my RS5 is in with my local independent at the moment for some investigation & diagnostics, so far it's not the battery 😳
Thank you RS5GW
ive looked on other forums and it could be differential sensor faults but hopefully not
its booked in tomorrow with Audi
This car has be faultless up till now !!!
will update when I get the problem from Audi
Thank you RS5GW
Hi too all
My RS5 had an oil pressure sensor intermittent failure .
Three sensors with the dual clutch differential and one sensor checks the other two for any discrepancies
Just want it fixed , back too how it should be !!!!
