Hello,
I've got a 2007 Q7 and the left reverse bulb has popped. Went to replace it and the screw holding the assembly in is broken the head of it is buggered. Anyone suffered this and if so how on earth did you go about removing the screw I can't get anything in the little access hole to do anything useful.
Cheers.
Hi,
You could possibly try and drill the head off the damaged screw if you are carefull.
19 hours ago, [email protected] said:
Hi,
Hi Brian,
Yeah that's most likely my only option, I mean how much damage can I really do drilling blind ;)
Cheers,
Chris
