Andyman220 Posted February 15, 2021 Posted February 15, 2021 Hey guys, I’m a new member here so sorry if I missed a previous thread, my car heater stopped working a few months back I have an a3 1.6 tdi I have looked online and did a flush on the matrix and no water would pass through it. I have bought a new matrix just abit unsure as how to strip the centre console to get to it does anyone have any pictures of then doing it or anything just to help me out??
Andyman220 Posted February 18, 2021 Author Posted February 18, 2021 Update changed the matrix wasn’t a bad job in all honesty but still not blowing hot air just aired. Going to replace the blending flaps next
FurioLx Posted February 20, 2021 Posted February 20, 2021 Hello mate, Do you have any fluctuation in your engine temp? Could be your thermostat not opening properly or could have an air pocket in your coolant lines resulting in it not getting circulated properly/hot coolant not reaching the matrix. Try a coolant flush if you can and see if there is any leaks around the thermostat housing where it bolts on.
Andyman220 Posted February 27, 2021 Author Posted February 27, 2021 On 2/20/2021 at 8:00 PM, FurioLx said: Hello mate, Do you have any fluctuation in your engine temp? Could be your thermostat not opening properly or could have an air pocket in your coolant lines resulting in it not getting circulated properly/hot coolant not reaching the matrix. Try a coolant flush if you can and see if there is any leaks around the thermostat housing where it bolts on. Hi mate yeah I tried that first that’s when I discovered my matrix was blocked stripping it down again on Wednesday I’ll post my results haha
