Just bought this got a few problems drivers door wont lock with key the alarm sets tho,drivers powered mirror doesnt fold , repeater for indicator on mirror doesnt work,  air bag warning light on.
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CGKA)       Labels:. 059-907-401-V1.clb
   Part No SW: 8K1 907 401 A    HW: 8K1 907 401 A
   Component: 2.7TDI EDC17  H01 0008
   Revision: 15H01---
   Coding: 0114002C02070120
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM27TDI0118K1907401A 001012
   ROD: N/A
   VCID: 2A5BB7AF4DFF20D47C-807E
No ASAM data for: "EV_ECM27TDI0118K1907401A" ()
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J217)       Labels:. 0AW-927-156.clb
   Part No SW: 8K0 927 155 AG    HW: 0AW 927 156 G
   Component: 0AW 27 TDIRdW H01 0002
   Revision: --H01---    Serial number: 0000000236
   Coding: 000001
   ASAM Dataset: EV_TCMVL381 A01015
   ROD: N/A
   VCID: 78FF5DE7C3D342443A-802C
No ASAM data for: "EV_TCMVL381" ()
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AC    HW: 8K0 907 379 AC
   Component: ESP8 front    H04 0060
   Revision: --------    Serial number: --------------
   Coding: 1A4500
   VCID: 7AFB47EFF5DF50544C-802E
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
   Part No SW: 8K0 907 064 C    HW: 8K0 907 064 C
   Component: BCM2 1.1      H70 0134
   Revision: 00002001
   Coding: 011000
   VCID: 306FA5C763235A04B2-8064
   Subsystem 1 - Part No SW: 8K0 959 754 D    HW: 8K0 959 754 D
   Component: FBSAUDIB8 IDG  H73 0083
   Serial number: 0817000076549010
   Subsystem 2 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
   Component: ELVAUDIB8  H36 0041
   Serial number: 0208000039707013
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 729 N    HW: 4E0 035 729
   Component: Interfacebox    H43 5170
   Revision: 00000000    Serial number: 329GT087593031
   Coding: 0025302
   Shop #: WSC 12345 123 12345
   VCID: 4487F917079BD6A466-8010
   Subsystem 1 - Part No: 8T0 919 609
   Component: E0380 BedienteilH08 0100
   Subsystem 2 - Serial number: 00000000123661
   Subsystem 3 - Serial number: 0128.07.080000000100010483ÿ
   Subsystem 4 - Serial number: 010483ÿ
Address 08: Auto HVAC (J255)       Labels:. 8Tx-820-043-3Z.clb
   Part No SW: 8T2 820 043 S    HW: 8T2 820 043 S
   Component: KLIMA 3 ZONEN H06 0140
   Revision: D0000000    Serial number: 0123.07.080985
   Coding: 36060000
   VCID: 428BFF0FDD8FD89454-8016
2 Faults Found:
00256 - A/C Pressure/Temperature Sensor (G395)
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 51
                    Mileage: 271662 km
                    Time Indication: 0
                    Date: 2008.05.28
                    Time: 11:58:09
             Freeze Frame:
                    Temperature: 10.0°C
00457 - Central Electronics Control Module / BCM (J519)
            013 - Check DTC Memory
             Freeze Frame:
                    Fault Status: 01101101
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 51
                    Mileage: 271662 km
                    Time Indication: 0
                    Date: 2008.05.28
                    Time: 11:58:09
Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
   Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
   Component: BCM1 1.0      H22 0253
   Revision: 04022001    Serial number: 00000000190408
   Coding: 26005091413CAF011609000000005D5D439D438800010141000000
   Shop #: WSC 06325 123 12345
   VCID: 2F6DA6BB7E1D45FCAB-807A
   Subsystem 1 - Part No SW: 8T2 955 119 C    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 240708  H11 0040
   Serial number: SWFBIE 0000116
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10205489
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000003107080098
1 Fault Found:
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 51
                    Mileage: 271662 km
                    Time Indication: 0
                    Date: 2008.05.28
                    Time: 11:58:00
Address 0E: Media Player 1        Labels: 4E0-910-111.lbl
   Part No SW: 8T2 035 110 C    HW: 8T2 035 110 C
   Component: MP3-Changer     H44 0390
   Revision: 00044003    Serial number: AUZ5ZBH8536423
   Shop #: WSC 00000 000 00000
   VCID: 2B55B2AB8A0539DC87-807E
1 Fault Found:
02261 - Data Medium
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 51
                    Mileage: 271662 km
                    Time Indication: 0
                    Date: 2008.05.28
                    Time: 11:59:00
             Freeze Frame:
                    Text: 00000000
Address 0F: Digital Radio        Labels: None
   Part No SW: 4E0 910 563 C    HW: 4E0 035 563
   Component: DAB-Tuner       H41 0830
   Revision: 00000001    Serial number: KE1276V8100774
   Coding: 0000001
   Shop #: WSC 02313 785 00200
   VCID: 24475997E7DBF6A446-8070
1 Fault Found:
00856 - Radio Antenna
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 51
                    Mileage: 271662 km
                    Time Indication: 0
                    Date: 2008.05.28
                    Time: 11:58:20
             Freeze Frame:
                    Voltage: 11.70 V
Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
   Part No SW: 8K0 919 475 D    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0020
   Revision: 11001001    Serial number: 52930821001826
   Coding: 100101
   VCID: 3A7B87EFB55F90540C-806E
Address 13: Auto Dist. Reg
Cannot be reached
Address 15: Airbags (J234)       Labels:. 8K0-959-655.clb
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD180BT6
   Coding: 30323433363030303030554A305238543053
   ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
   ROD: N/A
   VCID: 3C7781F7B76BAE641E-8068
   Subsystem 1 - Serial number: 6334MSME3E131A0FK
   Subsystem 2 - Serial number: 6344MSME3E31722FL
   Subsystem 3 - Serial number: 6352QSME6B660F27U
   Subsystem 4 - Serial number: 6362QSME78173841H
No ASAM data for: "EV_AirbaECUVWAUDI010" ()
2 Faults Found:
9443859 - ROD - Unknown Error Code
          - 00 [137]
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 271662 km
                    Date: 2008.05.28
                    Time: 11:58:10
9444115 - ROD - Unknown Error Code
          - 00 [137]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 271662 km
                    Date: 2008.05.28
                    Time: 11:58:10
Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
   Part No SW: 8T0 907 468 K    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0092
   Revision: EB302042    Serial number: 4200E08717823D
   Coding: 000303
   VCID: 4999E823E0B90BCC95-801C
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 18033866220708
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 51
                    Mileage: 271662 km
                    Time Indication: 0
                    Date: 2008.05.28
                    Time: 11:58:13
REQUIRED
Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
   Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
   Component: TSG FA        H07 1301
   Coding: 011F02225001120102
   Shop #: WSC 00544 210 91416
   VCID: 50AFC54703E33A04D2-8004
1 Fault Found:
00532 - Supply Voltage B+
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 51
                    Mileage: 271662 km
                    Time Indication: 0
                    Date: 2008.05.28
                    Time: 11:58:09
Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0112713909
   Coding: 011F0682003A0480022000
   Subsystem 1 - Part No: 8K0 951 177
   Component: DWA-Sensor  H02 0040
2 Faults Found:
03175 - Invalid Data Set
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 51
                    Mileage: 271662 km
                    Time Indication: 0
                    Date: 2008.05.28
                    Time: 11:58:09
01134 - Alarm Horn (H12)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 51
                    Mileage: 271662 km
                    Time Indication: 0
                    Date: 2008.05.28
                    Time: 11:58:13
End-------------------------(Elapsed Time: 03:24)--------------------------
any help will be appreciated
