Anton8 Posted March 17, 2021 Posted March 17, 2021 Hi Seem to have developed a cooling fan problem. After a short run with the engine only just starting to warm up, if I stop, switch off the engine, cooling fans still running, leave for 10 minutes, fans still running. Restart engine, immediately stop engine, fans stop! Sounds like some solenoid not doing it's work properly. Having a diagnostic check tomorrow, will keep you informed of patients health. Tony
Anton8 Posted March 18, 2021 Author Posted March 18, 2021 Well, It has never done it before. Somebody did say it could be something to do with the regen of the DPF.
beemerboy9 Posted March 18, 2021 Posted March 18, 2021 I can pass on two pieces of advice given to me. 1) Don't do short journeys in a diesel. 2) Use a high-quality fuel. I was advised to use Shell V-Power. You are fortunate in having an Adblue car as apparently they are less prone to DPF blockages.
Anton8 Posted March 18, 2021 Author Posted March 18, 2021 I'll let you know how I get on this morning.
Anton8 Posted March 18, 2021 Author Posted March 18, 2021 Hi Just got back from having the diagnostic check on the car. No fault codes!!! The garage checked every thing, air con, temp sensors, engine temp, nothing. Drove back home perfectly. Garage took their time checking, and did not charge me.
Anton8 Posted March 18, 2021 Author Posted March 18, 2021 Hi Cooling fans still running on. Went back to the garage with the fans running. Another diagnostic check. There are two engine temp sensors. One reading 87 degrees, second one reading 2000 degrees. I think that might be the problem.
