redbaron12 Posted March 18, 2021 Posted March 18, 2021 Hi, got a strange one if anybody has experienced the same. Some time ago my Audi 2.0 TDI 2005 started to loose coolant, it started causing starting problems, as if the coolant was getting into the engine and causing it to hydraulic it would eventually start but as time went by the starter could not turn the engine over. In the end i decided to get the head gasket done as I thought that was the problem. It seemed to cure it but again it has started to loose coolant and now my starter motor will not turn the engine over. I know its an old car but is in fantastic condition for its age so I do not want too part with it. Any Ideas guys. Many Thanks.
