SnoopGrog Posted March 30, 2021 Posted March 30, 2021 Hi, odd question so bear with me. I have a 15 yr old A3 2006, 1.6. I've never had the AC regassed, and it still runs cool, but not freezing, which to be fair is ok. (Had car since 2009). Is it possible that it's still functional after all this time, or am I imagining it? I could get it regassed but if it's common that it could still be working, I could save a trip. Cheers!
Stevey Y Posted March 30, 2021 Posted March 30, 2021 On 3/30/2021 at 7:21 PM, SnoopGrog said: Hi, odd question so bear with me. I have a 15 yr old A3 2006, 1.6. I've never had the AC regassed, and it still runs cool, but not freezing, which to be fair is ok. (Had car since 2009). Is it possible that it's still functional after all this time, or am I imagining it? I could get it regassed but if it's common that it could still be working, I could save a trip. Cheers! Expand Hi, its lucky it still feels cool you are supposed to regas every four years otherwise the moisture in the system builds up and rots the cods out of the condenser and evaporation units, I would get it done while you are ahead most regassing machines these days dredge out all the old gas and compressor oil and then pressure test the system if it passes it fills the system with new oil and gas, the old gas is run through a recycle and cleaned up, thats where the garages will make a profit from using the cleaned gas on the next vehicle, believe me you will notice the difference. Steve. 1
SnoopGrog Posted March 30, 2021 Author Posted March 30, 2021 On 3/30/2021 at 8:00 PM, Stevey Y said: Hi, its lucky it still feels cool you are supposed to regas every four years otherwise the moisture in the system builds up and rots the cods out of the condenser and evaporation units, I would get it done while you are ahead most regassing machines these days dredge out all the old gas and compressor oil and then pressure test the system if it passes it fills the system with new oil and gas, the old gas is run through a recycle and cleaned up, thats where the garages will make a profit from using the cleaned gas on the next vehicle, believe me you will notice the difference. Steve. Expand Ok thanks Steve, that's helpful and I'll get it sorted - cheers!
