A4 avant flywheel
Macer2408
Good evening am stuck on finding the right flywheel for my AUDI A4 B8 AVANT (8K5) 2.0 TDI 163 HP 2008 - 2015 WITH THE ENGINE  CODE CNHC  any help would be great fully
  • 1 year later...
Hi I have the same problem need a new clutch fitting as its slipping since DPF taken of and remap done. Called euro car parts and they said will have to take the clutch of first to see if it is a Sachs or a LUK flywheel its and Audi A4 2.0 tdi Advant 6 speed manual b8 anyone ever heard of this before apparently Audi inter changed with different flywheels
Edited by Firko401
Hi this is the problem with remaps you will probably have to buy an uprated clutch, LUK own Sachs so I very much doubt there is any difference as as long as the dimensions are the same the branding is irrelevant.
