Hi Gents, finally got round to changing the headlight bulbs on my A6 as I wanted a mild upgrade the original bulbs are five years old and getting a bit dim so I bought some aftermarket 5500k bulbs to replace the 4300 O.E. units, the Phillips units from Audi are super expensive as are they anywhere else so I opted for bulbs from a company called Limastar they work really well and give a much better light output and for £139.00 a pair with a two year warranty are also good value.
I wasn't looking forward to the change as the videos I watched looked fiddly regarding removing the headlight access covers as there is a strong possibility of dropping the screws down the wheel arch liner but the good news is they must have gotten fed up with it as well so they have redesigned it, the liner access fixing is a bit naff as they are brittle with age and snap, you can fix this as I did by using a plunge inner plastic trim clip through the aligning holes on the panel and arch liner.
Once in the rear headlamp cover is a simple twist off affair which exposes the bulb, the bulb is removed by twisting the entire unit to the ten to twelve position and gently pulling the bulb out, there is plenty of slack wire for you to unclip the connector, the other good news is the reflector assembly is made of alloy which removes the factor of the chrome burning off, a problem they had with the old glass type reflectors, the good thing is that there is no plastic locking collar to be attached to the bulb before mounting they are just direct fit, all good no ballast units to worry about as the ballast is built into the bulb this must have saved a fortune in production costs for this set up does not require headlight washers or levelling units at the front of the car.
