isleofwightandy Posted April 13, 2021 Posted April 13, 2021 Hi - just taken off sorn after winter, so got a little damp in cabin and boot(especially). No indicators/horn/ main beam/ wipers, etc. Thought it was a Steering Wheel Control Module fault. I've noticed now that if I quickly select reverse after starting up, it all starts working again until turn off the engine. Then they'll either keep working or back to square one - bit if I select reverse again, hey presto! Any ideas??
Steve Q Posted May 4, 2021 Posted May 4, 2021 All the wiring and electronics run along the bulkhead. I'd check to see if any of it is wet. Wet front footwells is a good giveaway. Water gets in via the battery tray if the battery tray drains get blocked.
