Channi Posted May 8, 2021 Posted May 8, 2021 Hi I currently have a convertible Audi TT the car roof had been playing up. It’s currently unable to automatically go up and down and has been manually put back into place. Can anyone help offer advice or recommend a specialist
Steve Q Posted May 8, 2021 Posted May 8, 2021 Various issues can cause the roof to stop working such as failing hydraulic pump, failing switches or clamps for example. At least you've confirmed that the movement of the roof isn't affected (often caused by objects getting jammed in the mechanics of the roof) which is a bonus. It might be worth getting an auto electrician to test the roof to establish what might have failed.
Channi Posted May 8, 2021 Author Posted May 8, 2021 Hi Steve thank you for responding. Where is ban auto electrician based? I also have another issue with the car something is causing the battery to drain but not sure if it’s connected to the roof problem. The last mechanic indicated & implied it could be the hydraulics on the car that have caused the roof problem but nobody has actually confirmed it
Steve Q Posted May 8, 2021 Posted May 8, 2021 1 hour ago, Channi said: Hi Steve thank you for responding. Where is ban auto electrician based? I also have another issue with the car something is causing the battery to drain but not sure if it’s connected to the roof problem. The last mechanic indicated & implied it could be the hydraulics on the car that have caused the roof problem but nobody has actually confirmed it Sorry it should say "an auto electrician". Best way to find a local one is via Google or local adverts. Your mechanic could be right to be fair.
Channi Posted May 8, 2021 Author Posted May 8, 2021 Hi thanks Steve I looked up a auto electrician & waiting for him to book in the car to get a dynastic done. Fingers crossed 👍
Channi Posted May 8, 2021 Author Posted May 8, 2021 Btw Steve thank you for your assistance, much appreciated. 😊
Steve Q Posted May 8, 2021 Posted May 8, 2021 24 minutes ago, Channi said: Btw Steve thank you for your assistance, much appreciated. 😊 You're most welcome 😊 it's what we're here for 👍
