2006 A3 2.0t fsi.
I’ve got a strange hissing noise in the car, it only happens when I’m in gear and when I’m not touching any pedals.
As soon as I touch the accelerator, even a tiny bit, it disappears and when I press the clutch in fully it disappears.
I don’t hear the noise when I’m in neutral or going below 10mph
Any ideas? I’m baffled?
Normally I would suggest an air leak to cause a hiss, but that would not be affected by clutch operation. Perhaps you are hearing the start of some belt slippage.
I had the cam and water pump done a couple of days ago. Could it be alternator? There’s no way to check, because when it’s sat idle it ticks over lovely.
Yes, press the belt inwards, it should barely move.
If the noise began immediately after having the cambelt and water pump done I would be suspicious that something had been neglected in re-assembly.
Thank you. I’ll speak to the garage!
