Electronic Audi Magnetic Ride Damping Cancellation Kit fot Audi TT TTS TTRS A3 S3 RS3
Can be used on all modifications of Audi TT and A3 such as TTS TTRS S3 RS3 only 8J and 8P
(2006 - 2013 m.y.)
Cancellation kits eliminate persistent malfunction codes that exist when upgrading a suspension on a vehicle with electronically regulated dampers.
00142 (008E) Left Front Dampening Adjustment Valve N336
00143 (008F) Right Front Dampening Adjustment Valve N337
00144 (0090) Left Rear Dampening Adjustment Valve N338
00145 (0091) Right Rear Dampening Adjustment Valve N339
Cancellation Kit will allow you to return the ability to turn off ESP and, as a result, return the launch control. If you are using simple or sports shock absorbers (not magnetic ride).
[email protected]
8j8p428620 185 $
