Flint123 Posted May 17, 2021 Share Posted May 17, 2021 How does the plate come away from the holder ? It seems secured with little 'lugs' all the way round and I don't want to just yank on it and bugger it up. Cheers Ian. Quote Link to comment Share on other sites More sharing options...
Shytot Posted May 17, 2021 Share Posted May 17, 2021 Have you got a picture of the problem? Quote Link to comment Share on other sites More sharing options...
Flint123 Posted May 18, 2021 Author Share Posted May 18, 2021 Quote Link to comment Share on other sites More sharing options...
Shytot Posted May 18, 2021 Share Posted May 18, 2021 I see the problem now - so it looks like a number plate holder. I've not seen one like that before - if the lugs are plastic then you can't bend them (like the back of a picture frame). So I guess you need to know if the holder is screwed or stuck to the bumper? I'd try using a magnet to see if there are any screws present If not, then assume it's stuck on, if so then try to bend a lug at either end and slide the plate out sideways .... Quote Link to comment Share on other sites More sharing options...
Magnet Posted May 18, 2021 Share Posted May 18, 2021 Hello Ian, The holder is usually screwed to the bumper, rather than stuck with double sided tape. However, you don’t need to remove the holder to change the plate. This holder has far more visible fixings than normal, but the way I would attempt to remove the existing plate would be to move the plate down in the holder as far as possible, before trying to move the upper lip of the holder up enough around the centre of its length to be able to start to tease the plate out. Warming the holder and plate with a hair dryer usually helps - principally in the area you are attempting to start removing the plate. Kind regards, Gareth. Quote Link to comment Share on other sites More sharing options...
Flint123 Posted May 18, 2021 Author Share Posted May 18, 2021 Thank you both, I'll see how I get on. Ian. Quote Link to comment Share on other sites More sharing options...
