SteveC1 Posted May 18, 2021 Share Posted May 18, 2021 Hi I have just brought an 09 A4 2lt turbo diesel -m the orange glow plug light has come on twice now, it goes into limp mode - if i turn off the engine and restart - it turns off and all is ok -- any ideas ? Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted May 18, 2021 Share Posted May 18, 2021 3 hours ago, SteveC1 said: Hi I have just brought an 09 A4 2lt turbo diesel -m the orange glow plug light has come on twice now, it goes into limp mode - if i turn off the engine and restart - it turns off and all is ok -- any ideas ? Hi get the car plugged in and diagnosed so that you have the codes for whatever is wrong, other than that it could be a sensor,EGR valve, sticky turbo vanes, DPF, the list is endless and without codes I wouldn't care to speculate. Steve. Quote Link to comment Share on other sites More sharing options...
SteveC1 Posted May 18, 2021 Author Share Posted May 18, 2021 2 hours ago, Stevey Y said: Hi get the car plugged in and diagnosed so that you have the codes for whatever is wrong, other than that it could be a sensor,EGR valve, sticky turbo vanes, DPF, the list is endless and without codes I wouldn't care to speculate. Steve. 2 hours ago, Stevey Y said: Hi get the car plugged in and diagnosed so that you have the codes for whatever is wrong, other than that it could be a sensor,EGR valve, sticky turbo vanes, DPF, the list is endless and without codes I wouldn't care to speculate. Steve. Cheers yep looks like sticking turbo vanes Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted May 19, 2021 Share Posted May 19, 2021 Hi before condemning the turbo try giving it a good blast with Lucas turbo and ego cleaner which is simply sprayed down the air intake pipe while the engine is running that should loosen it, my money is on a worn EGR valve which won't normally show up a code until knackered but is still capable of leaking extra gas which in turn eventually clogs the turbo and kills the cat. Steve. Quote Link to comment Share on other sites More sharing options...
