Shytot Posted May 21, 2021 Posted May 21, 2021 Hi, I've had my 2l TFSi for a month or so now and the gearbox generally responds well and chooses the "right" gears. I've started visiting my work office once a week and although most of the drive is motorway / A roads the last mile or so is down a reasonably steep hill. I've noticed that the auto gearbox seems to select a very low gear for this hill (2nd or 3rd) but it doesn't seem to compensate for the speed that I'm actually doing (maybe up to 30/35 mph) and so I get this very laboured high revs and to be honest it doesn't sound healthy. I don't have hill assisit or hold on and the simplest thing to do is to switch to manual and change gear (or slow down!) but it is a bit annoying. I've previously travelled down this same hill in a 3l diesel and never had the issue - but that is a lower revving engine and it was an 8 speed auto gearbox. It's not a showstopper but just wondered if anyone can offer any input as to why this might be happening. On my VW I could reset the gearbox with ignition on and foot flat down on accelerator for 10 seconds - but I don't think that would solve this.
Steve Q Posted May 21, 2021 Posted May 21, 2021 Just seen this: https://www.audiworld.com/forums/q7-mkii-discussion-211/going-down-gear-2914297/ Doesn't seem to off a cure though, sorry. And this for dsg: https://forums.whirlpool.net.au/archive/2371332 1
Shytot Posted May 21, 2021 Author Posted May 21, 2021 Thanks Steve 👍 Looks like it's a feature! It just sounds awful. I'll blip the throttle to recover if I don't want to listen to it.
Steve Q Posted May 21, 2021 Posted May 21, 2021 15 minutes ago, Shytot said: Thanks Steve 👍 Looks like it's a feature! It just sounds awful. I'll blip the throttle to recover if I don't want to listen to it. You're welcome, sorry I can't help more. Just seems a characteristic of the s tronic/dsg box.
Shytot Posted May 21, 2021 Author Posted May 21, 2021 43 minutes ago, Steve Q said: You're welcome, sorry I can't help more. Just seems a characteristic of the s tronic/dsg box. Yes I realised after posting that the VW was not DSG and wasn't as "clever"! 😁 1
Shytot Posted June 9, 2021 Author Posted June 9, 2021 So after a bit more experience it is definitely using engine braking - so it should be "economical" As an offshoot it also helps on cruise control when you are decelerating. Going from the 70mph (ish) setting to 50/55 for roadworks on the m6 (they're working overnight apparently) just by dropping the CC in 5 mph decrement it uses engine braking to get your speed down rapidly - for me it's a very useful feature 👍
