Hi wonder if someone could post a picture showing the location of the MAP sensor on a 1.6 diesel engine.  Had a good look but cant find it?
tia
tia
Hi, Just an educated guess but I have worked on a couple of 1.6 Skodas and the map sensors on them are at the front of the engine where the boost pipe runs across the front and the MAP is mounted on a rigid plastic pipe in the middle, easily spotted as its the only thing on the boost pipe under there that has wires and a plug on it.
Thanks Stevey, I had hoped I could have got to it without having to go under the car - think i will just put it to local garage.
