Forestier Posted May 22, 2021 Posted May 22, 2021 I have spent a day trying to find this information on the web. Where do Audi put the amplifier for the radio in the B6 Cabriolet? It is a non Bose 2003 A4 B6 Cabrio. (N.B. It is the actual radio speaker amplifier, NOT the antenna amps in the boot lid) I have a parasitic drain in the radio circuit, Fuse 39. I pulled the radio head unit and the circuit still shows the drain so I now want to check the amplifier. I hope someone has done this and has the information on location. HELP please!
audia4b5kev Posted May 22, 2021 Posted May 22, 2021 behind the pannel in boot right hand side and multi changer in left side
Forestier Posted May 23, 2021 Author Posted May 23, 2021 Found it! Thanks for the information, especially the you tube video. Amp is a Blaupunct, (knew it wasn’t Bose). Now I have the part number! If disconnecting the amplifier makes the current drain dissapear, then I will source a second hand item. Can’t check that until tomorrow as I blew the fuse in my multi meter. Thanks again.
Nathanj Posted May 29, 2022 Posted May 29, 2022 Does anybody know where I can find a replacement aerial module for an s4 b6 convertible part no au465 8H0035225J Thanx in advance
