AndreiZambo Posted May 27, 2021 Posted May 27, 2021 Hello everyone Recently I purchased Obdeleven pro and I run I scan . This is what I found . How I can fix them ? Also I want to mention that I dont have any light on my cluster --------------------------------------------------------------- 02 Transmission System description: 0CK 20TFSIRdW Software number: 8W0927155B Software version: 0007 Hardware number: 0CK927156S Hardware version: H04 Serial number: 0000000458 ODX name: EV_TCMDL382021 ODX version: 002021 Long coding: 000001 Trouble codes: U010000 - Lost Communication with ECM/PCM Intermittent U010000 - Lost Communication with ECM/PCM Intermittent. 01 Engine System description: 2.0 R4 TFSI Software number: 8W0907115K Software version: 0003 Hardware number: 06L907309A Hardware version: H40 ODX name: EV_ECM20TFS0118W0907115K ODX version: 001004 Long coding: 0A2500132324050334080000000000000000000000000000 Trouble codes: U112300 - Databus error value received Intermittent 03 Brakes System description: ESP9 Plus Software number: 8W0907379E Software version: 0593 Hardware number: 8W0907379J Hardware version: H06 ODX name: EV_ESP9BOSCHAU49X ODX version: 012014 Long coding: 04AA089910A40A9915A5489A00835292E6A59220100850A812004A4967A549 Trouble codes: U112100 - Databus missing message Intermittent U112100 - Databus missing message Intermittent U112100 - Databus missing message Intermittent U010000 - Lost Communication with ECM/PCM Intermittent U010000 - Lost Communication with ECM/PCM Intermittent U010000 - Lost Communication with ECM/PCM Intermittent U010000 - Lost Communication with ECM/PCM Intermittent U010000 - Lost Communication with ECM/PCM Intermittent U112100 - Databus missing message Intermittent U010000 - Lost Communication with ECM/PCM Intermittent U112100 - Databus missing message Intermittent U112100 - Databus missing message Intermittent C105400 - Left front tire Tire pressure warning - too low Intermittent C105600 - Right front tire Tire pressure warning - too low Intermittent. 5F Multimedia System description: MU-P-LND-EU Software number: 8W0035035P Software version: 0358 Hardware number: 8W0035035A Hardware version: 051 Serial number: A666K0FB001028 ODX name: EV_MUHig6C3Gen2HBAS ODX version: 001115 Long coding: 01940101FF0A000013111101000A00332F0001E701700100DE Trouble codes: B106113 - Left front treble speaker Open circuit Intermittent B106613 - Left rear treble speaker Open circuit Intermittent.
Stevey Y Posted May 27, 2021 Posted May 27, 2021 Hi welcome to the world of diagnostics, best advice is clear them all, pump up the tyres all round and reset the TPMS on the MMI, i get a load of rubbish codes like this as I use my car as a cab and do a lot of milage so they rack up I just clear them all about once a month you will soon learn that the only codes worth worrying about are the ones that put up an EML and throw you in to limp mode. Steve.
AndreiZambo Posted May 27, 2021 Author Posted May 27, 2021 Hi Steve Thank you for the reply . I cleared them and tonight I run again the diagnostics and it looks all good now , no faults/errors at all . Thank you for the advice ! Andrei.
Stevey Y Posted May 27, 2021 Posted May 27, 2021 21 minutes ago, AndreiZambo said: Hi Steve Thank you for the reply . I cleared them and tonight I run again the diagnostics and it looks all good now , no faults/errors at all . Thank you for the advice ! Andrei. Hi my pleasure these things have a code for every minor occurrence in the Can Gateway system, just have a clearout every so often and your world will be at peace with your Audi, like I say its the codes that throw up a light that will need close attention. Steve.
