Magoo Posted May 27, 2021 Posted May 27, 2021 Hi All totally new to this and not a petrol head so advice or experiences would be appreciated. I bought a A4 Quattro 62 plate through lockdown. As per a previous post on an A3 the test drive at low speed was fine but when I then started taking it on the motorway a vibration developed at acceleration between 65-75mph (once the engine had warmed up). When I took my foot off the accelerator the vibration stopped but as soon as I accelerated the vibration returns. So far I have had the tyres aligned, Engine Mounts and gearbox mounts replaced and also the Propshaft joint regreased. (apparently a problem on BMW Z4 previously) First day out the garage and not a problem but day 2 and the vibration is back!!! Any ideas would be gladly received, Cheers
Magoo Posted May 27, 2021 Author Posted May 27, 2021 On 5/27/2021 at 7:38 PM, Magoo said: Hi All totally new to this and not a petrol head so advice or experiences would be appreciated. I bought a A4 Quattro 62 plate through lockdown. As per a previous post on an A3 the test drive at low speed was fine but when I then started taking it on the motorway a vibration developed at acceleration between 65-75mph (once the engine had warmed up). When I took my foot off the accelerator the vibration stopped but as soon as I accelerated the vibration returns. So far I have had the tyres aligned, Engine Mounts and gearbox mounts replaced and also the Propshaft joint regreased. (apparently a problem on BMW Z4 previously) Should of said 77k on the clock First day out the garage and not a problem but day 2 and the vibration is back!!! Any ideas would be gladly received, Cheers Expand Sorry should of said 77k on the clock
Stevey Y Posted May 27, 2021 Posted May 27, 2021 Hi could be a deformed tyre or the wheels need balancing. Steve. 1
