Does the 3.0 tdi engine have a connection on top to attach an oil suction tube to remove engine oil ?
Hello Tom,
Pending someone coming up with the specific answer, then the rule of thumb is, if it hasn’t got a sump plug then it must have a suction facility. Does it have a sump plug?
I think there should be a sump plug. As such this would be the best way to drain the oil.
