milmorguy Posted June 5, 2021 Share Posted June 5, 2021 Taking the S3 Quattro to Switzerland for an extended period and will need Swiss registration. Does anyone know if "LHD" headlights will be a straight swap and whether these would be available in the UK? Thanks Mike Quote Link to comment Share on other sites More sharing options...
Steve Q Posted June 5, 2021 Share Posted June 5, 2021 They should be a straight swap. However, before you go out and buy new lights. It might be the case that your headlights can be adjusted for continental Europe. This would have to be done by a computer I believe if possible. Quote Link to comment Share on other sites More sharing options...
oake Posted June 6, 2021 Share Posted June 6, 2021 Probably not relevant to your S3, but the headlights on my 2017 A3 can be adjusted for driving on the right via MMI. The dipped beam doesn't convert totally to LHD mode, but just flattens the left edge of the beam, but I've always found it adequate. http://www.instruccionesaudi.com/A3/en_GB/onboard/o_m00200.htm Apologies if you've already been through this, and found it doesn't apply to your car! 1 Quote Link to comment Share on other sites More sharing options...
milmorguy Posted June 17, 2021 Author Share Posted June 17, 2021 Thank you both for your help. I'll follow this up. Mike Quote Link to comment Share on other sites More sharing options...
Steve Q Posted June 17, 2021 Share Posted June 17, 2021 3 hours ago, milmorguy said: Thank you both for your help. I'll follow this up. Mike You're welcome 😊 Quote Link to comment Share on other sites More sharing options...
