Kieran1995 Posted June 8, 2021 Posted June 8, 2021 Cold start engine noise sounds rotational this has been happening a while now and cannot seem to get to the bottom of it since this started I have had the car in to the garage and had a genuine Audi cambelt changed along with all tensioners etc. The garage has removed the auxiliary belt and started the car and the noise still remains. This noise only happens when the engine is cold and when it warms up it disappears but only when engine is at full temp. I have also changed the oil thinking maybe the existing oil may of been too thick causing it to take time until it was thinner to circulate the engine. The car is a 2015 Audi A3 2.0tdi 150hp IMG_2298.MP4
guerraffandre Posted October 30, 2021 Posted October 30, 2021 Hi, I have the same exact car, audi a3 8v 2015 2.0 tdi 150hp, and it does the exact same noise only when it's cold. Have someone find what's the issue ?
Magnet Posted June 24, 2023 Posted June 24, 2023 Hello Kieran, If you are still on here - did you sort out your noise after? Kind regards, Gareth.
Stevey Y Posted June 24, 2023 Posted June 24, 2023 12 hours ago, Magnet said: Hello Kieran, If you are still on here - did you sort out your noise after? Kind regards, Gareth. Don't hold your breath. Steve. 1
guerraffandre Posted June 26, 2023 Posted June 26, 2023 Hi, I have made 45.000km and the noise is louder and worst! But it's running... no one knows the issue but I think it's something on the cam shaft (just a guess tbh) So it will continue like this until it breaks ahahah Let's keep updating the thread until we solve this pls 🙂
Paulish Posted June 26, 2023 Posted June 26, 2023 Audi themselves must know the issue: I have limited time to arrange a booking. But will investigate further.. get differing mechanics opinions
Paulish Posted July 14, 2023 Posted July 14, 2023 The noise is… vaccuum oil pump. Replace. Bottom of engine. An issue of failure at anytime with 2.0 diesels old or new. 1
guerraffandre Posted July 14, 2023 Posted July 14, 2023 Could be the vacuum oil pump! I'll replace it and give feed back if it's solved
Paulish Posted July 14, 2023 Posted July 14, 2023 That would be great to hear back if issue fixed. Strongly believe this is the problem. The noise from a failing oil pump I’ve heard recently sounds identical to the rotational noise we are all experiencing
Guest Posted May 9, 2024 Posted May 9, 2024 IT is normal there is nothing wrong with it.. I have same car faster 184bhp and exact same noise I have.. the thing is when from factory car is and parts never been replaced or disconnected it is fine.. As soon as car had removed fuel hose pipes the air entered there and it will not create vacuum immediately Now I have even worse sound now like regular intervals it does whistling.. Apparently when doing cambelt and u disconnect all fuel hoses u need to bleed it same like when brake fluid is bleed from callipers to remove bubbles..
Guest Posted May 9, 2024 Posted May 9, 2024 On 7/14/2023 at 10:12 AM, guerraffandre said: Could be the vacuum oil pump! I'll replace it and give feed back if it's solved it's not oil pump but fuel pump 😉
