Mike2020 40 tdi quattro Posted June 12, 2021 Posted June 12, 2021 Keep getting this fault now and again any ideas why?
Steve Q Posted June 13, 2021 Posted June 13, 2021 Have you checked to make sure that the camera (behind the rear view mirror) isn't obstructed by some muck thrown up from the road (or down by a passing bird? Also try turning your lights off (or to manual) and then back to Auto again. HBA will only work with the lights set on Auto.
Steve940 Posted June 17, 2021 Posted June 17, 2021 I had this and also Lane assist failure and something else...it was the wing mirror adjuster toggle.turned to some unknown symbol...oh and wing mirrors were folded and didn't unfold....returned to normal.neutral and all good
Mike2020 40 tdi quattro Posted June 26, 2021 Author Posted June 26, 2021 Spoke with audi and they also pointed on the front camera being obstructed by something. Problem hasn’t come back in the last two weeks so it’s all good for now 1
chrisjw Posted March 3, 2022 Posted March 3, 2022 (edited) Can anyone tell me If high beam assist is standard on a late 2021 40 tdi Avant? Just about to switch from a 69 plate A5 sport back s line which does have this standard so I hope it does! many thanks chris Edited March 3, 2022 by chrisjw
Mike2020 40 tdi quattro Posted March 3, 2022 Author Posted March 3, 2022 1 hour ago, chrisjw said: Can anyone tell me If high beam assist is standard on a late 2021 40 tdi Avant? Just about to switch from a 69 plate A5 sport back s line which does have this standard so I hope it does! many thanks chris Hi Chris mine is 2020 model and does have high beam assist and the only option I have is tech pack so I think it’s standard
jammy Posted March 5, 2022 Posted March 5, 2022 On 3/3/2022 at 9:46 PM, chrisjw said: Can anyone tell me If high beam assist is standard on a late 2021 40 tdi Avant? Just about to switch from a 69 plate A5 sport back s line which does have this standard so I hope it does! many thanks chris Standard on S-Line models and above.
Harris Drann Posted June 21, 2022 Posted June 21, 2022 I have a 17 plate A6 with matrix head lights with high beam assist. My right hand side headlight high beam has stopped working and causing an error message to be displayed (high beam assist faulty) on my dash every time I turn on my high beam assist. I’ve had the right hand side headlight checked the high beam is NOT faulty, but when I flash my head lights only the left head light flashes. Has anyone had a similar issue or know were the fault could be?
