Hi all,
I've joined up because i'm completely stumped by this oil leak.
So what's happening is i'm getting 3 different puddles of oil all at the front and in a line that seem to be running off the top of the sump  I've had the bumper off and most of the front of the car except for radiators etc trying to find it but can't see anything. It doesn't help that I had the auxiliary belt fail and everything is now covered in rubber.
I only get puddles of oil after i've driven the car at full temperature ,parked then switched off the engine. If I quickly popped to the shop I don't get any drops at all
also if I start the car on the drive and let it get to full temperature before switching off I don't get any drops of oil.
If it helps the car has only done 65k.
