Door electrics not working
Bob Gunston
Hi Guys
hopefully you can help!
I have a 2012 S5 and the rear drivers side door electrics are no longer working
so I cannot lock doors, open window, and puddle and red light not working.
All others doors are working fine
any help greatly received
thanks
bob
My first port of call would be to look for broken wires in the loom. The wiring runs into the door from the b pillars of im not mistaken. You'll need to move the rubber sleeve to see the wirers at that point. If they're intact then you'll need to remove the door card to inspect further.
5 hours ago, Bob Gunston said:
Thanks Steve
You're welcome. Your alternative option is to have a diagnostic check to see what fault codes flag up. Or take it to an auto electrician.
