abox036 Posted July 1, 2021 Posted July 1, 2021 Hi, I've stupidly just reversed into a van, luckily got away with just a broken tail light lens, was looking to replace it myself to save cost, is this possible does anyone know? And if so how would I go about sourcing parts and fitting? Thanks
Stevey Y Posted July 1, 2021 Posted July 1, 2021 41 minutes ago, abox036 said: Hi, I've stupidly just reversed into a van, luckily got away with just a broken tail light lens, was looking to replace it myself to save cost, is this possible does anyone know? And if so how would I go about sourcing parts and fitting? Thanks Hi try eBay or a general google, I have never replaced one of these but if you find a replacement unit the studs on it will give you a good idea of where to undo the nuts on the rear of the unit once you have removed the rear interior trim in the boot. Steve.
abox036 Posted July 1, 2021 Author Posted July 1, 2021 1 hour ago, Stevey Y said: Hi try eBay or a general google, I have never replaced one of these but if you find a replacement unit the studs on it will give you a good idea of where to undo the nuts on the rear of the unit once you have removed the rear interior trim in the boot. Steve. Hi Steve, Thanks I'll have a look around and give that a try. Adam
