ZEE-A6 Posted July 12, 2021 Posted July 12, 2021 Recently bought an Audi A4 2.0 TDI 170 Quattro Manual on an 09 plate. The car has done 164k miles so it’s not exactly low however Iv had an issue since, when the car is both cold and warm it shakes on idle. There is no smoke, loss of power or warning lights, in fact it moves quick. However it shakes a little and sometimes feels like a shudder, anyone have any idea what it could be? Thanks Zee
Brian74656 Posted July 14, 2021 Posted July 14, 2021 On 7/12/2021 at 7:22 PM, ZEE-A6 said: Recently bought an Audi A4 2.0 TDI 170 Quattro Manual on an 09 plate. The car has done 164k miles so it’s not exactly low however Iv had an issue since, when the car is both cold and warm it shakes on idle. There is no smoke, loss of power or warning lights, in fact it moves quick. However it shakes a little and sometimes feels like a shudder, anyone have any idea what it could be? Thanks Zee Expand Mass airflow sensor maybe
Adam B Posted August 1, 2021 Posted August 1, 2021 That happened to me just before the timing chain went on me, best get it looked at….if you have breakdown cover get them out.
Magnet Posted August 1, 2021 Posted August 1, 2021 Hello Zeeshan, Does depressing the clutch when idling, make any different to the shuddering? Kind regards, Gareth.
Brian74656 Posted August 1, 2021 Posted August 1, 2021 Check your timing belt and make sure its in good condition, and does it shudder when you raise your clutch pedal
Brian74656 Posted August 1, 2021 Posted August 1, 2021 On 8/1/2021 at 4:08 PM, Brian74656 said: Check your timing belt and make sure its in good condition, and does it shudder when you raise your clutch pedal Expand It could be an issue with your mass airflow sensor or maybe something else with your fuel air flow mixture set up
Magnet Posted August 1, 2021 Posted August 1, 2021 Well, all rather academic now, since the original poster hasn’t returned to the forum since he placed the post.
ZEE-A6 Posted August 1, 2021 Author Posted August 1, 2021 On 8/1/2021 at 1:17 PM, Magnet said: Hello Zeeshan, Does depressing the clutch when idling, make any different to the shuddering? Kind regards, Gareth. Expand This is the thing, I did try seeing what happens if I press the clutch up and down as I was trying to pin it down to being the flywheel.. it didn’t make any difference
ZEE-A6 Posted August 1, 2021 Author Posted August 1, 2021 On 8/1/2021 at 4:08 PM, Brian74656 said: Check your timing belt and make sure its in good condition, and does it shudder when you raise your clutch pedal Expand The alternator pulley is starting to make a noise now and after taking a look it seems the belt around it has seen better days too
ZEE-A6 Posted August 1, 2021 Author Posted August 1, 2021 (edited) On 8/1/2021 at 7:38 PM, Magnet said: Well, all rather academic now, since the original poster hasn’t returned to the forum since he placed the post. Expand Apologies.. iv also been trying to deal with an engine light on my 15 plate A6 😂 not having a brilliant time with Audis at the moment Edited August 1, 2021 by ZEE-A6
Brian74656 Posted August 5, 2021 Posted August 5, 2021 On 8/1/2021 at 9:41 PM, ZEE-A6 said: Apologies.. iv also been trying to deal with an engine light on my 15 plate A6 😂 not having a brilliant time with Audis at the moment Expand Hope you have sorted both cars out now
neverlack Posted September 5, 2024 Posted September 5, 2024 Gonna reply to maybe revive this post, I'm having similar troubles on my 11 plate..
