Brian74656 Posted July 15, 2021 Posted July 15, 2021 Hi Guys I have just purchased a a black edition tdi quattro A5 177bhp.i have a dead fly in my headlight unit and can't think of a way to get the fly out, is there a simple solution
Steve Q Posted July 16, 2021 Posted July 16, 2021 The only way it can get in is at the back assuming the lense isn't cracked etc. You'll have to remove the headlight to gain full access to the rear abd then shake it out. 1
Brian74656 Posted July 16, 2021 Author Posted July 16, 2021 3 minutes ago, Steve Q said: The only way it can get in is at the back assuming the lense isn't cracked etc. You'll have to remove the headlight to gain full access to the rear abd then shake it out. Thanks I was hoping I wouldn't need to take the light out lol
Steve Q Posted July 19, 2021 Posted July 19, 2021 On 7/16/2021 at 5:53 PM, Brian74656 said: Thanks I was hoping I wouldn't need to take the light out lol It is annoying I'll give you that
Stevey Y Posted July 20, 2021 Posted July 20, 2021 Hi another possibility is if the lights are HID remove the inspection covers and bulb and gaffer tape a smaller piece of tubing to a vacuum cleaner hose waggle the pipe around inside the headlamp unit and suck it out. Steve. 1
Shytot Posted July 20, 2021 Posted July 20, 2021 You could always send a spider in..... to catch the fly...... 😁 😁 😁 The vacuum cleaner sounds like a good idea 👍 1 1
