Jodiemenziesxz Posted July 27, 2021 Posted July 27, 2021 Does anyone know why my Audi A3 sport won’t go into reverse or 5th gear? It will go into reverse if forced in after a few attempts, want to try get advice of here before it goes into the garage, would also like to try giving it a go at fixing it myself if it’s a possible easy fix. thankyou.
cliffcoggin Posted July 27, 2021 Posted July 27, 2021 You have not mentioned what sort of gearbox it has, but assuming it's a manual transmission the problem is most likely a worn clutch. When was it last changed?
Jodiemenziesxz Posted July 27, 2021 Author Posted July 27, 2021 It is a manual 5 speed gearbox sorry, and the clutch seems perfectly fine, goes in to all other gears fine
Jodiemenziesxz Posted July 28, 2021 Author Posted July 28, 2021 8 hours ago, audia4b5kev said: STRETCHED CABLES BUD Is that the linkage cables? Been told it’s possibly that
cliffcoggin Posted July 28, 2021 Posted July 28, 2021 14 hours ago, Jodiemenziesxz said: It is a manual 5 speed gearbox sorry, and the clutch seems perfectly fine, goes in to all other gears fine Tell us the bite point of the clutch. In other words at what pedal height does the clutch start to engage? If it is much less than half way up you have a clutch problem.
