Passenger door
DEREKCO2
Any ideas my front passenger door will not unlock using the remote all other doors are fine it opens from the inside but not the outside could it be the actuator or a fuse maybe 2008 A4 b8
  • 1 month later...
Ok update on front doors not opening from key fob well I bit the bullet and took the door cards off removed the door lock took the little grey cover off and cleaned the linkages then used bicycle wet lube oil on the linkages and clips hey presto everything works2342CCAF-D62E-43F8-9050-7BD6D465DB34.thumb.jpeg.7edcfcbbe97482d38017d6d5705033c2.jpeg2342CCAF-D62E-43F8-9050-7BD6D465DB34.thumb.jpeg.7edcfcbbe97482d38017d6d5705033c2.jpeg82B98331-B837-4939-9DFB-56602E7D2C1B.thumb.jpeg.520b274e810846f28cee8c0c7f092114.jpeg82B98331-B837-4939-9DFB-56602E7D2C1B.thumb.jpeg.520b274e810846f28cee8c0c7f092114.jpeg10A5321B-FEC5-4F36-815D-A095F35ACB71.thumb.jpeg.5b5a4d18491c1e452c2101164fd900c4.jpeg
