jeff111 Posted August 11, 2021 Share Posted August 11, 2021 Hi need help with an A6 2.0 tdi injector fault .when running car was only running on 3 cyl out of 4 . scanned found injector 4 was at fault over fueling . now removed injector ready for testing . If a replacement is needed does it need programming to car just for info . car had the low oil pressure light on Replaced turbo and feed pipe , still had light on . replaced the balancer shaft and key way. Any help would be appeciated Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted August 11, 2021 Share Posted August 11, 2021 2 hours ago, jeff111 said: Hi need help with an A6 2.0 tdi injector fault .when running car was only running on 3 cyl out of 4 . scanned found injector 4 was at fault over fueling . now removed injector ready for testing . If a replacement is needed does it need programming to car just for info . car had the low oil pressure light on Replaced turbo and feed pipe , still had light on . replaced the balancer shaft and key way. Any help would be appeciated Hi, this is only an educated guess but how long had this problem been on going?, it possible the extra fuel has got in with the engine oil, check the level, this would have the effect of thinning the oil making it harder for the pump to work, sort the injector and it will need re coding then sort out the low pressure light. Steve. Quote Link to comment Share on other sites More sharing options...
jeff111 Posted August 11, 2021 Author Share Posted August 11, 2021 Hi only injector fault now . low oil pressure was due to the balancer shaft keyway issue Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted August 11, 2021 Share Posted August 11, 2021 1 hour ago, jeff111 said: Hi only injector fault now . low oil pressure was due to the balancer shaft keyway issue Hi one less to worry about, do you have the facilities to reprogram the new unit?. Steve, Quote Link to comment Share on other sites More sharing options...
jeff111 Posted August 17, 2021 Author Share Posted August 17, 2021 Hi not sure have carly . so possibly . but will be fitting it tomorrow get back to you Quote Link to comment Share on other sites More sharing options...
jeff111 Posted November 3, 2021 Author Share Posted November 3, 2021 Hi at last the car runs, but on starting when car is at tempreture it shakes, when restarted its not getting up hill very well and tried carly to re program, but it wont have you got the facilities to reprogram the injector. cheers Jeff Quote Link to comment Share on other sites More sharing options...
